My xperia ZR touch screen automatically responding without human touch.. When I press the power btn to unlock the mob. it is automatically getting respond as well as I open the menu it automatically open any of the app and responding that app...dont know what is going on..I have repair the software android 4.3. But the problem is still there...looks like ghost is in my phone...pls help me.
Solved! Go to Solution.
Do you have any 3rd party screen protector on the phone? In that case, try to remove it.
Otherwise I would suggest that you have your phone examined by a service center. Please contact your local Xperia support team for more information:
I have not remove the original protector...I have to visit service centre...bt want to know the reason.
I recommend that you do not remove the original anti shatter film (ASF) from the phone. The service center should be able to tell you what's wrong with your phone.
Thanks....I have submitted the mob in service centre.
Hey Hi Ramij_raja,
I m also facing the same problem since two weeks.
wat update u gt from service center.
They updated ur software?How manys days they took?
could u pls give me this information.
My Xperia ZR fell on the floor and got a crack dividing the screen. Now the left side of the screen is not functioning anymore. Is this covered by the warranty. Is the possibility to replace the screen? What shall I do?
Thanks
I have the same problem.
but I found out the reason.
I usually sweat a lot. and after talking in the day light with my Xperia ZR, the screen is wet. screen sensor is based on heat and because of my face sweat the screen surface is stiil hot and the device think screen has been tuched by my finger.
in this cases, I usually press the power botton and screen goes of, then i let the screen to be cold.
this issue also apears when you are charging the mobile, so the battery goes hot and it affects the screen.
the only way is let the screen to be cold.
hope it helps
i have a similar problem with my phone. The touchscreen just start working by itself sending messages, deleting contacts and it also freezes sometimes
I bought this phone around 3 years back in mid 2014, just recently it's touch has stopped working around certain areas in display. I think this is a digitizer problem. Did someone faced this issue? If yes then please tell me the solution. I am attaching a touch test picture too. The display is completely fine and working perfectly, just the touch has stopped working.The complete left side strip and the right bottom part is not working.
