In new version of Android 6 z3 the phone speed very low and signal wifi very weak is very bad please fix the bug
Solved! Go to Solution.
Same problems with my z2 tablet. I am having problems there where I never had problems before. Same issue with different routers. That means that problem is not in router. Low signal and signal loss.
Did you try repairing software with pc companion?
No, have not done that.
What can repair software do? Actually what software repair does? It has nothing to do with WiFi.
Same problem as mine. I compared my z2 runnning on marshmallow against my Zultra wc runs kitkat. My z ultra can detect my router maybe 30 paces after the front door. The marshmallow Z2's wifi plummeted after only 10 paces. I hope this is just a bug, if so, please fix it.
no wifi and no bluetooth!!!!! im out of warranty so ill have to pay for the fix my self. very poor from sony, trading standards here i come this is last peace of sony hardware i buy. ive probability got 5k of sony tech at home and have used there phones for 5 years and now i feel so let down!!!
