Bonjour,
Depuis un retour de l'étranger, ma barre d'etat n'affiche plus que l'heure (avec secondes) et les notifications. Mais plus de trajet du reseau, de l'itiberance des données, etc...
J'ai reussi a remettre wifi et batterie mais pour les deux premiers je be vois aucune solution, comment faire ?
Merci
Hello,
Since returning from abroad, my status bar only displays the time (with seconds) and notifications. But more of the network path, the itiberance of the data, etc ...
I managed to put wifi and battery but for the first two I see no solution, how to do?
Thank you - GT
Solved! Go to Solution.
Hi @Zoffyo, welcome to our forum!
Your question has been translated to English as this is an International forum, please post any replies in English and it will be easier for me and other users to assist you.
It does sound like you may have enabled the System UI tuner and made some changes in there.
If you go to Settings and scroll all the way down, do you see a setting called "System UI Tuner" here? If you do, tap on it > tap the three dots in the top right corner > Remove from settings. This will revert everything back to normal.
Let me know if that helps!
