Hi,
How do you set up the speed dial buttons for frequently used numbers?
The Answerphone is set, can't seem to find a way to set the other buttons!
Any ideas anybody?
Thanks...
Not sure about speed dial like phones of yester year but there is a widget which says top contacts if it helps
As always there's an app for that
https://play.google.com/store/apps/details?id=com.speeddial.jozsefcsiza&hl=en
Hi Archiver,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
You can also add contacts to the homescreen for faster calling to specific contacts.
1. Tap and hold finger on Homescreen
2. Tap Apps
3. Tap Shortcuts
4. Tap Direct Dial
5. Choose contact
Once chosen the contact will be added to the Homescreen and can simply be pressed to make a call.
i hope this helps.
Thanks Jake...
I really wanted the old fashioned press and hold the dial pad number like my Nokia and Samsungs...I'm sure I will get used to this new way!
Thanks again...
No problem, Im sure you will be fine
I don't see a Direct Dial option. Is this only available using Simple Home option?
Just tried pressing numbers 2-8 for 10 seconds to try to assign a speed dial number and nothing happened. No speed dial menu opened. Does my dialer app have a bug?
Came form an LG phone to Marshmellow and found the phone app to cumbersome. I had to do extra keystrokes. So I bought "True Phone", which was like the old LG app with speed dial.
Also, this app goes directly to the dialing pad and skips the call list. Since I seldom call same person twice within a short period, this behavior is extremely counter productive. True Phone is much better. It shows the call list and the dial pad on the same screen.
