sound recording
heppy
Visitor
sound recording
Hi,
I have purchased my Sony for only a couple of days. I am wondering if my Sony Z5 Compact can do sound recording? I have looked through it but couldn't found any apps to do so. Please give me some advice as I will need it to record my lectures.
Thanks
4 REPLIES 4
bubimir13
Visitor
Download Sound recording app from sony at Play Store. Or any other.
John-BR
Visitor
Hi @heppy
Welcome to the community.
Yes the Xperia Z5 Compact can record sounds, but if there isn't a preinstalled app that performs that function you will want to install one from the Google Play Store. For example here is one that we have madehttps://play.google.com/store/apps/details?id=com.sonymobile.androidapp.audiorecorder&hl=en
Phanisayana
Visitor
Hi,
Thanks for your help. Yes, I was checking for the pre- Installed app in the mobile and as it was not there, I was surprised. Thanks, will download the app and do the required.
NeoBeum
Enthusiast
@Phanisayana wrote:
Hi,
There's an official Audio Recorder app
Screenshot_20171218-200248.pngScreenshot_20171218-200311.pngScreenshot_20171218-200129.pngScreenshot_20171218-200240.pngScreenshot_20171218-200337.png
