so i removed the backcover and no improvment so am going to replace the camear and see if that works next week. i looked at other image sample of the z2 form techradar and other yotubers so this waht image techrader took http://www.techradar.com/reviews/phones/mobile-phones/sony-xperia-z2-1226987/review/6. so i did the same i used an lg g3 and my z2 to take an image from my bedroom window and this is the result. The first one is the sony xperia z2 and the second one is the lg g3. As you can see the z2 just can't foucs at all. Dose anyone earls face this issuse or is it just me
That's terrible, where are you going to buy the camera module?
From a trusted websit where i buy all my other parts from thet are all oem and i got a hold of another z2 the camear worked fine so it going to cost my £35 for a camear so i hope that fix the issue
I dont even use the Sony camera app anymore - the focus is TERRIBLE. Just use Camera FV-5 rather - perfect focus there
sins I got the camera replaced and this only happened yesterday and then it went a wat and came back again so I don't know this issue. As u can see in the pic there a black spot. So I tool of the back cover same issue and when I restated mY phone it was gone but it came back
i am also having focus problems with my z2. i tried everything i am able to do but focus just doesnt seem to work
Hi, I've the same problem. How did you fixed it?
Hey. I have the same issue. Did you replace the câmera? Did it works?
Same issue!!!
