Hi. On my pretty new Experia Compact phone i started to get some funny messages after about 2 months use. The phone suddenly startsmaking a beeping sound, and a black box with a message is flashing on the main screen. The box says: Reading error, try again. This is translated from Norwegian language, in Norwegian it says: lesefeil, prøv igjen. This message keeps popping up until i turn the phone off and on again. Then the phone keeps quiet for some days, and then it starts again. Anyone have a good fix for me??
Regards
Terry
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
I guess that you have the NFC function activated on your unit. Go to Settings > More... > Unmark NFC.
I gave an explanation on this in another thread, I suggest that you check the following link:
http://talk.sonymobile.com/t5/Xperia-Z1-Z1s/Help-Read-Error-Try-Again/m-p/393807#M1209
