Hi,
Since 6 days I am a new user of Sony Xperia Z1 Compact (had previously Xperia Arc S) and since the beginning I have been facing strange problems with proximity sensor or other thing associated with it (some kind of drivers, software or something else).
When I start dialing and put the phone near my ear the screen goes blank immediately as it should be. When I take it away from my ear the screen wakes up with 0,5 sec. delay what is completely acceptable for me but this 0,5 sec. delay is only during dialing.
When a phone call is started then this delay is about 2 or 3 sec. and sometimes screen wakes up when the person I was talking to has ended the call. It is completely unacceptable and very annoying. Sometimes, during phone call, I do not want to end it but I need a keypad or check something etc. and I do not want to wait 3 sec. or more for phone response.
Sometimes I wonder if the person I am talking to did not end the call then the screen will ‘never’ wake up.
As I said I have this phone for a few days and I have a very few apps installed from Google Play Store on it– no other that I had on my Xperia Arc S.
I have searched some forums and noticed that this problem exists and there is still no solution for it.
Could you, Sony guys/technicians, tell us (Xperia Z1/Z1s/Z1 Compact users) if you are aware of this problem, please? Is it hardware or software problem? Are you working on solution? Is it possible to fix it by simple software update? When can we expect the proper update to solve the problem?
Regards
Grzegorz
Solved! Go to Solution.
Today I can confirm that KitKat update solves the problem.
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
That sounds strange. Do you use any screen protector?
Do you get the same result if you clean/wipe the sensor area?
@Johan wrote:Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Hi,
I do not use any additional screen protectors or covers. It is just pure Z1 Compact out of the box
My sensor area was/is clean and I am completely sure of that.
Maybe I was not precise enough, sorry. The 'delay situation' I was talking about is the most often situation. Sometimes during the phone call, proximity sensor works as it should be - immidiate response.
Proximity sensor passes 'Diagnostics' app test flawlesly.
The only application related to 'calling' I use is 'exDialer' but I have been using it for 2 years with Xperia Arc S and everything worked fine. I uninstalled this app for test but it didn't change anything.
I have had mine for 2 days and noticed as I frantically wave my hand for about 2 secs in front of the screen when finished on a call.
Hi,
I think that problem is quite well known at least from Xperia Z1.
For example: http://talk.sonymobile.com/t5/Xperia-Z1-Z1s/proximity-sensor-issue/td-p/378373
You can find similar cases on XDA forums.
The only problem is that Sony doesn't want to admit that problem exists. At least I haven't found another Sony's question but "do you have any cover or protector".
Additionally I am quite convinced now to have another problem with my Z1 Compact. Many times voice of a person I talk to is getting metallic with some kind of little vibration, little distorted - I don't know how to describe it. Generally, voice is not clear.
It is a smartphone but it is still A PHONE. In this phone basic phone's functions doesn't work properly. I have started wondering to give it back and get my money back. Unortunatelly, in Poland it is not so easy.
Same problem here : new z1 compact 4 days of use, screen is clean, no protection on it.
I had a Z1 before it, and never encountered this kind of problem...
Hope this is just software problem...
I had this problem too, but went away after I rebooted the phone and ran the calibration tool a few times it started working.. keeping fingers crossed it won't come back as it's pretty annoying when it happens. I suggest setting hang up to power button so you can hang up and use the phone in case this happens..
