My Xperia Z3 Compact is about 6 weeks old (US-unlocked) and recently the phone quit ringing audibly when I have an incoming call. When I get a call, the screen comes on and shows that I have a call, the phone vibrates like it always does and the LED flashes bright white. But no sound, no ringtone. Actually - a very quiet ringtone but through the small phone receiver speaker (where you listen to a caller with phone to your ear). All other notifications and stuff sound out normally: SMS, email, alarms, startup sound, music all work fine. Only incoming calls have no ring volume. I have checked the volume settings and have the ringtone & notifications volume slider wide open. I have changed ringtones, adjusted every sound and volume setting on the phone to no effect.
I did a hard reset and that did not solve the problem. After hard reset I let the phone update as necessay (the phone was up to date, many Sony apps updated). I did not re-install my data and called my phone a few times after the hard reset, still no ring sound on incoming call.
I did another hard reset and did not let anything update, still no ring sound on incoming call.
Related to this is the fact that on any phone call, the speakerphone does not work. If I turn on speakerphone, the caller can hear me but I cannot hear them. If I turn off speakerphone, everything is fine (I hear the caller in the earpiece, they hear me). The external speakers do work fine, I can play music, video, etc. and it all sounds fine. I have tried all of the different ringtones and they sound fine except for when someone is calling in and I hear nothing.
As an aside, this phone has not been dropped or wet or any of those things that might have created a problem.
Any ideas?
Thank You!
I've successfully solved the issue by following your tricks.
Its awesome!
Thanks this solution helped me to solve my phone's problem
@Keru wrote:
I have the same problem it all started with the marshmallow update my phone doesn't ring on incoming calls tried to change the song to custom nothing still no sound
My Z3 dual Phone vibrate led and the two speakers are working
My solution only temporary :
1) setting > sound > change the ring to nothing
2) restart your phone
3) go and undo the first step > choose one
That's it it works for me every time
After analysing the presses I think that the phone is having a problem with memory access
Thanks this solution helped me to solve my phone's problem. An effective way
Though its late but want to post my reply to leave a solution for people who have encountered the same problem. I have uninstalled an App which was actually voice changer/recorder, and restarted my cell. my problem solved.
Worked for me Thanks
im using xperia z2, and i cant find how to uninstall file comander
I just clear default in my file comander, then in settings, sound and notifications, phone ringtone menu I choose sounds picker and pick any song, and my phone works fine now,
Thanks for your idea, in my case it's correct that problem with my file comander, because if I pick any song from file comander then the incoming calls will have no sound
