So ,I have this problem now .Today I received a mesage from Sony telling to plug my phone to the computer in order to check if the new update was available for my phone .
I plugged my phone ,but completely forgot to check the charge status .Then I got a call while the phone was plugged on the computer and PCCompanion was dowloading the update .
It told me the update failed .
So I unplugged my phone ,then plugged it again and restarted the whole update process .It went through and told me the update failed once again .I unplugged ,then put my phone off .And plugged it back to the computer to try the update again .
A third attempt which didn't go through .
So after these three attempts ,I unplugged it to the computer and put it to charge on the wall then tried turning it on .
Here's my problem : The LED is red ,the SONY logo appears on my screen ,and then the phone just goes off .
It does this repeatedly whle the phone is on charge .I'm looking at it right now ,it's plugged on the wall charge ( not the dock ) and it keeps showing the red LED ,then the SONY logo ,and goes off .
What should I do ?
Solved! Go to Solution.
Hi rocky i have a seam problem whits my xperia z its writing me "the softwear ........" plzz if you repair your phone sad me how i can to do plzz
To perform a system repair - This will factory reset your phone
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
OMG im ready to scream. Had notification to update my phone. waited 4 hours and then it said failed. now constantly turning on n off saying the error message. isnt charging, wont connect to PC. I have no idea what to do ive presed power and volume, pressed red button in sim card slot PLS HELP
Hi All,
I am having terrible issues with my xperia Z, its slow in every way. USB point has no indication about the right side of inserting the chager and sometimes I ed up inserting the charger in wrong way, as a result phone used to shut down and then I had to restart. But today I inserted the charger in wrong way, phone got switched off and not is it not starting, not even charging. I have tried force restart ( ON + Vol up button) , even this is not working. It is all black screen, this is so frustrating, pls help me what should I do
I want my phone back in working condition.
above solution does n't work on my sony d2005 mobile,
Thank you so mutch man ,,, i look over the hole internet for this answer .. thank you .. thank you ..!!!!!!!
Hi,
I have a similar problem....my Z1 was running low on battery. when it finally shut-down it was saying "upgrading android", but then it totally shut-down. I started charging it, but after a few % charge, i tried to turn it on......it comes on, but it crashes...not even a message of some sort ....nothing appears,it stays like it's on, but it does nothing....pls help
How can i stop the loop of restarting thingy ?
It went endless and my handphone already through this for 3 hours..
I already tried the power and volume button. It didn't stop my handphone from restarting..
PLs help,
in my xperia z3 it doesnt charge only it just displays that and shutsdown pls help
@uliwooly wrote:Try this
connect your phone to the wall charger > press andhold power & volume up > let it charge for 1 or 2 hours > after 2 hours > repair your phone with SUS
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Bridge (for Mac)
Bridge (for Mac)
Bridge (for Mac)
