Multitask after update 6.0.1 (Marshmallows)
SOLVED
Ahmadbajrai271
Visitor
I am a kind of guy who use multitask a lot...i always surfing at Facebook and replay to one of my friend on Whatsapp and i get no problem changing between the apps !
But after the update i got some problem with it...it seems that Marshmallows is taking a lot of RAM, when i was on playing CoC (Claah of Clans) and my alarm goes on and I turned it off but the surprise was the game refresh back !!!!!
My brother has Z3 Compact and when he plays CoC and at the same time he msg someone on Whatsapp and go to FB and return to the game, and it continue from the last time he left it over !
So what the huh ?!
Is there going to be a fix of this or not !!
Tags (1)
35 REPLIES 35
Uliwooly
@Bekammk
Repair the phone with XC, it will smooth things out
Xperia Companion (XC)
Software Repair Guide
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
tamrox
Visitor
Updated a couple of weeks ago and my z3 compact has been slow, battery life is rubbish and it gets really hot, all since the latest software update - anyone else having similar problems?
It was absolutely fine before; no storage issues, battery would last all day (now charging two to three times in the day ONTOP of the the nighttime charge), and the it wouldn't get as hot as it does now (even with slight use).
eskevile89
Visitor
Guys i see SOLVED in the title but can't find where... I got the same problem and it's really annoying, especially considering that my tablet with less resources goes far better...
PapaFraku
Visitor
Hello there Slightly_smiling_Face
After the update to 6.0.1 on my Z3 Compact I collected some bugs I noticed. I want to know if some of you noticed them too.
- When I want to write a quick reply with the new feature in Whatsapp my screen doesn't react anymore. So I'm on my lock screen, tap the quick reply button and after that the screen doesn't react anymore. I don't know if it's just Whatsapp or because of the new update.
- The WiFi signal disappears. I'm on my phone and I turn WiFi on. And after 5 seconds of having a signal it just disappears.
- And the RAM Management is very bad. Once I just opened Hay Day and had to switch to Whatsapp for a message. And when I went back to Hay Day it had to restart the whole game.
- There are also heating problems. I play games as long as before I made the update and it is so hot afterwards on the backside.
- And I also can't find the notifications numbers above my apps on the Xperia Home Launcher.
If there are questions just ask. Because I want to know if I'm the only one. Sony support via email didn't help at all. There was just an automatic reply.
Tags (4)
Uliwooly
@PapaFraku
I believe most of them have been posted before, you could use the search bar, but it'll be wise to re-install the latest update, it should smooth things out
PapaFraku
Visitor
Okay thanks. I'll try it. I am just a little bit annoyed by the fact, that Sony itself isn't able to help me...
litch1
Visitor
How would you go about re-installing the latest updates?
Uliwooly
@PapaFraku
This is a user based forum, so you could contact your Local support
@litch
Restore
Visitor
I am having xperia Z3 plus with latest update of 6.0.1.
My issue is that notification led is not blinking when am having a missed call or text messag when the screen is locked. But while changing the fone led is lighting. And when battery is low the led is blinking.. And in text message setting led notification is ticked.
I have done the test at that time led is blinking in all color.
Any body having any idea about this
Uliwooly
@Restore
Do you have stamina mode on? or doze on?
