Left corner of my Z5 is missing, is the device still water resistant?
SOLVED
Mr98
Visitor
 Hola, se me salio la esquina del z5, es un plástico chiquito, eso perjudica su capacidad de sumergirlo en el agua??
Hello, I left the corner of the z5, it is a small plastic, that hurts your ability to submerge it in the water ??
-GT
Tags (1)
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.PT.title
NunoSEN2
Hero
@Mr98;
Dial in the phone app the *#*#7378423#*#* to enter the service menu and select Service Tests>Pressure Sensor. The pressure should increase as you press the display.
Please have in mind that even if your phone is still water tight you should not submerse it in water, read this:https://support.sonymobile.com/global-en/xperiaz5/dm/waterproof/
3 REPLIES 3
NunoSEN2
Hero
Hi @Mr98;
Try a pressure test in the service menu (*#*#7378423#*#*) and see how it behaves.
Mr98
Visitor
Como hago tal prueba de presión?
How do I do such a pressure test?
GT
NunoSEN2
Hero
@Mr98;
