FORGOT SCREENLOCK PIN
karlok
Hello... I'm using SONY XPERIA Z1
What can I do if I forgot my screenlock PIN?
Do I need to reset the phone?
IF reset is needed, how can I reset my Z1 at home?
45 RISPOSTE 45
Ravi75
Pls assist me to unlock my z1 as I hv forgot my pin
Jonas
Master
Hi @Ravi75, sorry to hear about this.
Have you tried any of the previous troubleshooting that I have posted earlier in this thread? If you haven't done that, I'd recommend that you do that!
Let me know how it went!
Amirtelecom114
Jonas
Master
Hi @Amirtelecom114, welcome to our forum!
If you have a Google account in your device and you have previously activated the MyXperia service you can login with your Google credentials at the link below.
myxperia.sonymobile.com
Press on your phone and wait for the service to locate your phone > Lock > enter a temporary 6 digit PIN code and unlock your phone with the new PIN code.
If you don't have the service activated in your phone, you will need to perform a software repair using Xperia Companion. Do note that doing this will delete all data stored on the internal storage of your phone and since the phone can't be unlocked, creating a backup won't be possible.
I hope that helps and let me know how it went! Slightly_smiling_Face
Kls1979
I have Sony xperia zl and forgor my pin. I do d not own a pc and  factory restart doesn't seem to work.    I I been trying for 12 he's.    Help!  somebody please.!!!!
Uliwooly
Krysh
I forgot screen lock pin. How to unlock it?
S23
Forgot my pin
Jonas
Master
Hi @S23, sorry to hear about this. Slightly_frowning_Face
I would recommend that you perform a software repair using Xperia Companion. This will however delete all data stored on the internal storage, but it will remove the screen lock in the same process.
Let me know if that helps!
Mhofela
Sony model 02005 typePm 067 bv
