Solved! Go to Solution.
Thanks Ottotriin! You're a genius.
In case anyone needs the instructions to turn off the setting again, Android 5 this is where I did it:
Google Now > Settings > Voice > "OK Google" detection.
All kudos to you. It was driving me nuts
When the "OK Google" detection is enable on any screen, the FM radio app does not output any sound. Everything else in the FM radio app works, e.g. tuning, but no sound.
After disabling the "OK Google" detection, the FM radio works again.
However this "OK Google" setting has a bug of it's own. Every once and a while in enables itself automatically.
Pretty annoying.
just turn off ___ from any screen____ option in "OK GooGL" ..... and it will start working !!!!!!
