Copy and paste a website link
SOLVED
152bobby
Visitor
Hello,
A simple quick question.
How do I copy and paste a website address and add it as a link in a email, text or whatever?
I know how to copy and paste text, but the same method seems to not work for Website pages.
Thanks
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.US.title
Qatrium
If you are using Chrome:
- On the address bar, tap once to reveal the full adress of the webpage, then tap twice on the address to mark it.
- Shortcuts for cut, copy, and paste will appear. Choose copy (two sheets of paper icon).
- Use the "Recent applications" softkey to navigate through recently opened app and choose your email app.
- Long press on message area and choose paste option.
4 REPLIES 4
Qatrium
152bobby
Visitor
I knew that was a easy one and I swear that's what I was trying to do and it did not work.
Just tried it again and it works.
Must have been the way I was tapping the screen or possibly where my other hand was holding the phone, as this does affect some functions on my phone.
Thanks for your help.
Qatrium
No problem, glad we could help.
Phy
Legend
Legend
That's cool, glad you figured it out. Seems to me Quester gave you the correct answer.
