Bluetooth connection Z1 Compact and Tablet Z
SOLVED
Savoie
Visitor
Hello,
I am having difficulty establishing a bluetooth connection between my Z1 compact and tablet Z (both running 4.4.4). I can pair the devices but not extablish a connection.
Bluetooth on the phone works fine with a in-car hands free device.
Have tried all the usual, unpairing, restarting, pairing steps with no improvement. can anyone help?
1 ACCEPTED SOLUTION
Accepted Solutions
Savoie
Visitor
Thanks for this suggestion. I did a repair of both the phone and the tablet with PCC - no change.
However, I have found the solution! While setting Xperia Link between the two devices I discovered that there is a setting "Use at home" in the Device settings. When this is checked the bluetooth conncetion is automatically turned off when both devices are connected to the same WiFi network.
I guess I could have spotted that one sooner and saved myself a lot of time and effort!
Thanks again for your help!
5 REPLIES 5
Uliwooly
How about settings > apps > all > smartconnect > clear data
Savoie
Visitor
Thanks for this suggestion. I have done this on both devices and am still unable to connect.
Some additional information:
I have just noticed that when I click on the paired device (my phone) on the tablet. The device greys out and shows 'connecting' after that I see 'connected' for a fraction of a second. However, the connection is immediately lost
I am able to establish a bluetooth connection from my tablet to my laptop (so bluetooth is working OK)
During my unsuccessful attempts to connect the phone and the tablet there are no other devices connect to either by Bluetooth
Uliwooly
You could repair your phone with PCC
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Savoie
Visitor
Matkeez
Visitor
hello, I am now having exactly this issue with xperia z3 and z3+ phones and xperia z4 tablet, and also when trying to connect to e.g. iPhone. I have no issues using BT keyboard. Wifi is turned off on all devices, but anyway: could you please help me where can I found setting "Use at home"?
