Do you experience this issue with a particular router or with multiple routers/WiFi?
Does this happen while you use the phone or when its idle?
test it in >>> safe mode
Hi @nacionmclen,
I'm sorry to hear this.
Do you connect to a 2,4 GHz or 5 GHz Wi-Fi network? If it's 5 GHz, is it possible for you to try a 2,4 GHz Wi-Fi instead (or vice versa)?
Would it be possible for you to take a bug report? I can then forward it for investigation.
To do this:
When the report is ready you will receive a notification. Tap the notification to share it. I suggest you upload it to Google Drive and then choose to share a public link to the upload and include the link in the PM.
[Link removed by Christofer]
