Android 9 - wrong optimization for 720p screen
EminOd
Visitor
The icons in the notification curtain are incorrectly located, the leftmost icon and the rightmost icon have a small indent from the edge of the notification curtain; when opening the curtain, only 6 icons are placed. Navigation bar is too wide. When you open the "Menu for Developers" and put there 380 dpi, instead of 360 dpi, everything looks fine, the indents are symmetrical, the navigation bar is of normal size, though everything else is a bit smaller than usual ...
0 REPLIES 0
