Xperia Z1 Compact Charging Problem
Hzmy
Visitor
hey guys , i own this xperia z1 compact, i try to charge it but there's nothing happened, i try so many times , what should i do? please help me
Tags (1)
6 REPLIES 6
profile.country.RO.title
sebikorek
New
Hello. Try to connect the phone via the USB cable to a computer and see if it is charging. If it is, your charger might be broken and you need a new one. Or the cable is broken so it won't work with the computer either. Try different options like a different charger and different cables until you get a result. If nothing works, the phone might be damaged so you need o send it to a repair service.
Good Luck!
Alexander1
Champion
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Just as suggested above you should try to charge the phone using another charger. Also try to press and hold the power button and volume up at the same time until the device vibrates. You could also try to press and hold the off button behind the SIM card cover:
http://userguide.sonymobile.com/referrer.php?region=global-en&product=xperia-z1-compact#Resetting-yo...
After the phone has vibrated you can try to charge the phone a few hours and then try to start it again.
Finsh
Visitor
Hello...!
I have Xperia z1 and it's. Not charging, when ever I connect the charger it continues blink red light which is not stable in-spite of full night charging connection...what could be the problem...
haneef1
Visitor
same with me guys... solution please..?
NikolaTattoo
Visitor
I have the same problem, I did not know what to do. But in one moment I heat it up with a hair drier and it start charging. 😕 but when its cold it stopped again. I was heating it up all the night Face_with_open_Mouth 😕  Now I'm truing to update software, maybe it helps somehow 😕
spyke
Visitor
Same problem here with Sony Xperia Z3 compact.
I found that switching off the phone, and then charging it while off, got the phone fully charged.
