Hello ,
I have recnylu installed a custom rom aokp4.3 bcs sony didt realsed there own update
I wanted to swap memories to instal apps on ext card
I have installeld an application from google play
Then swap faild so I tried to enable swap parition and changed the swap location from /dev/block/mmcblk1p3 to /dev/block/mmcblk1p2
Then I rebooted my phone to see if it works but , sadly I HARD BRICKED MY PHONE !!!!
I taked it to the repair service then they told me there is a problem in a part of the motherborad IC Power and it must to be replaced but the bigest problem is that this part isnt avabile in my country , I live in egypt they told me to take my phone to an offcial sony repair clint they may help
Please what am I suposed to do in this situation ? Why does sony sells phones without giving it is fixes in any case , or can I fix it myself ? The phoje dosent boot on cwm neither flashmod nor fastboot , does flashing a kernel fix this ? If so then how can I flash it without fastboot and flashmod and cwm ???
When I plug my phone into a wall charger WITHOUT a battery it give me a red led blink for 1 second then nothing when I plug it in my laptop it detect a zeus flash device when connecting the phone one charger and it give a red blink I had conngected the battery fast then the red blink lasted longed for 15 sec then turned off agin ( didnt tried this mehod on laptop )
Please help me I need an offcial from sony that know his work very well
Thanks
Regards
