Xperia SP WIFI range ISSUE
ak_newlife
Visitor
Hi, i have just bought Sp 2 days back
I am facing wifi range problem the device does not catch the range where my other phone catches the range at good wifi signal strength.
the distance is like 3 to 5 meters less then my black berry
Is there any settings that i need to see for the wifi range.
205 REPLIES 205
Ygandran
Visitor
Bro i have been searching for the past 2 days n  i have hundreds of scroll but i still cudnt seem to find 'ConnectivityThereshold=-87'... i request a small help from ur goodself, cn u pls provide me with a screenshot?
Viola
Visitor
Same here SP dropping WIFI connection even I am near to the WIFI, have the latest Jelly bean . Looks like need one more update to fix this problem.
Help me Mods
porkflaps
Visitor
Hi there.
I managed to find the txpowercap but cannot find anything which says ConnectivityThresholdDBM.
I have rooted my Xperia SP and edited just the power cap but it made little difference.
Can i just insert a new line into the file?
Thanks
rowlf74
Visitor
I had the same issue. Connection to wifi would drop off all the time and really hack me off. Decided not to meddle with router settings but deleted the connection from the sp then reconnect using WPS not ssid and passcode. Wifi has not dropped in three weeks. Hope this helps anyone.
Anmol1
Visitor
Exactly! This problem shouldn't be there when we spend 23k rupees Slightly_frowning_Face
Anmol1
Visitor
Even cheap phones don't have these problems. This problm is terrible. Wifi stops working, have to turnoff and turnon again. Wastage of time. Slightly_frowning_Face
