Xperia does not charge or breaks up charging
Ret0
Visitor
Hey,
here's a problem: some time ago, I've plugged my phone to charge overnight and I was woken up by continiung beeping of pluging and unpluging charger. Instead of charged my battery was depleted. I've replugged it and went back to sleep, by the time i woke up, phone was fully charged. From this very day my charger was failing more and more often to the point it was completely unusable (it still charges but constantly breaks up and refuses to cooperate).
I've realized that this could be solely charger failure, so I've bought a new one, but overtime same thing happend, charging started to break up and battery was depleped instead of being charged. Today, the very same thing started with my trird charger after two maybe three weeks of using it.
I use only ofiicial sony equipment.
Presing power+volume does not help, same thing happens only without sound.
Is it a charger failure, maybe I've got bad cable or something is wrong with my electricity? Or is it a hardware failure, in that case is it worht to fix it or should i start thinking of buying new phone?
3 REPLIES 3
Uliwooly
@Ret0
Have you tested different wall chargers and/or cables?
Ret0
Visitor
Yes, I did. In fact I was testing different combinations of cables, chargers, phones, rooms even countries. Each time results were similar, phone was not charging or break up the charge until was set in a random "correct" position.
Uliwooly
@Ret0
It could be a hardware issue, contact your Local support to get it inspected.
