Wireless PC with Marshmallow?
Tropinota
Visitor
Hi, I have two questions about this terminal:
1º.- I received a Z2, warranty, with the new Marshmallow and I need to connect wirelessly to your PC and laptop to transfer files, but with this new softward that possibility is not contemplated. This need is given because I have to connect and disconnect many times a day and I want to protect both the "front" as the connector (physical) USB. Are there plans to implement this option in future updates? or, if this possibility is not contemplated Is there any other alternative that can use ?, Can Lollipop again?.
2.- When trying to install the APP "Snapdragon BatteryGuru" tells me that "my device is not compatible with this version" What brings this terminal processor?. This APP and had installed in the previous Z2 smoothly and indicates that the web has a "quad-core processor 2.3GHz Qualcomm MSM8974AB" What is the problem?.
Thank you very much.
Translated with Google Translate.
11 REPLIES 11
Tropinota
Visitor
Hello again @alexdon, What should I do to have LOLLIPOP again?. Marshmallow not meet expectations or needs to ask my Xperia Z2.
profile.country.RO.title
_alexdon_
Bear in mind that there is no official way to downgrade your device. Take a look here:
/t5/Software-Updates/How-do-I-go-back-from-Marshmallow-to-previous-Lollipop/td-p/1104201
alexdon
