hello guys
my phone working good .. when i using it i found the touch from the top left corner of the screen doesnt work ,, i must restart the phone to work again ... any solution for this problem ?
check if it works while on safe mode but then again it could be a hardware issue, based on your past post
you should get your phone inspected by your Local support
it working good but after using more times the touch not working i must restart phone to work again
question : after boot in safe mode what can i do to test my phone ?
aha . ok i will try it and tell you again
Same problem here ... Did u reach any solution ??
i sold my phone because iam bored from it
i think the touch begun damage
