Touchscreen problem on a flat surface
Priya3
Visitor
Hi i think u hav very much familiar with sony product, my problm was .....recently i hav purchased sony c5ultra dual, wen i kept my phone at any surface touch screen is nt working until and unless i hold it thru my hand then only it works properly ?????can u help in this issue pls
5 REPLIES 5
Phy
Legend
Legend
Do you experience the same on safe mode?
How to boot on safe mode
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
How to boot on safe mode on Lolipop
1. press and hold the power key
2. once you get the pop up menu
3. press and hold "power off"
4. Boot on safe mode should become available
Vegetiger
Visitor
hi
i am also having this issue. Is your led Innolux or truly? Can check by typing  *#*#7378423#*#* and see the ID of the panel.
It seems innolux have better sensitivity but Sony Customer Service stated only have panels of Truly..
Mine sent to warranty to change the LCD and still waiting (nearly a month).
IndraOey
Visitor
My Xperia C5 Ultra dual have the same problm. I dont know why.
But when i hold my phone it's going normal again.
:smileyangry::smileyshocked:
ybhatt05
Visitor
I too have the same problem. Another problem is that sometimes the touchscreen operates properly only if I use my thumb. If I use my fingers then the phone is not able to detect the touch properly and then starts misbehaving. Phone automatically opens an application on which I have never tapped.
haidyhaiyee
Visitor
Same problem here since the day i bought it. So disappointed with Sony.
