Pls help, back-home buttons is not working
Ayame
Visitor
Hi there, im having a problem with my z1, the back and home button are continuosly tapping even if i dont tap them, i already tried to reset to factory setings but it didnt fix the problem, i cannot use my phone bec of that, pls help me
9 REPLIES 9
Uliwooly
@Ayame
Does your phone has a protective case, film, glass?
Ayame
Visitor
Yes, before, but i already removed it, still the same problem
Uliwooly
@Ayame
Check if you experience the same in >>> safe mode
CameronT
Champion
Hi @Ayame,
Welcome to the community.
Just to be sure, there's no physical damage on your phone such as hairline cracks?
Ayame
Visitor
@uliwooly
Ive followed the instructions to safe mode, but im still having the same problem =(
Ayame
Visitor
No issue if the original screen has any cracks, but the protective glass i used before has many cracks on it, thats why i removed it
Uliwooly
@Ayame
you might want to double check, as there might be hairline cracks as @CameronT said
Ayame
Visitor
What do u mean by hairline cracks, very very thin cracks,?? If it doe
s have, what would be the solution?
Uliwooly
@Ayame
Yes, thin cracks, if it has cracks then you will have to contact your Local support to get the device repaired
