I have an issue with my notification LED, first of all it works, all of the colors are displayed, and everything, the only issue I have is that it is always turned on in a red color, all the time, it just changes to show other notification colors, so even if my battery is 100% the red LED will be turned on.
If y try tu remember, I think this started since one time that I put the phone on the water, and then after having waited for it to dry I put it to charge, and since then the LED hasn't turned off. I tried restarting several times and even did a factory reset. help pls!
It sounds like it could be a physical issue based on the fact that this happened after it was exposed to water. You may have to contact your local support team to arrange a repair, but before doing that, try a software repair.
