no incoming calls
Not applicable
no incoming calls
Any ideas on what I have not set everything other than incoming calls is good...
3 REPLIES 3
sushidushi
Contributor
Have you tried ringing your mobile phone from another phone?  Are the calls not getting through at all, are they being forwarded to another number, or is it simply that your phone isn't ringing when you receive a call?
The following applies to the big X10.  It will be a bit different on the mini or mini pro.
If it's just that the phone is not ringing, it might be that you've set it to silent.  Press the menu button and select settings - sound and display.  The first box in the menu is for 'Silent mode'.  If there is a tick by that, tap it to remove the tick.  Also look at Ringer volume, the next box in the list.  There is a bar under incoming call volume.  If the slider is to the left, there will be no incoming call volume; drag the slider to the right to resolve that.  You can also adjust the volume of incoming calls by using the volume buttons on the right hand side when you're looking at the phone (with the display facing you!)
You don't give much infortmation in your message.  If the above doesn't sort things out, post more details, including which of the X10 phones you have, and with any luck someone will be able to help you.
Not applicable
I have not received calls every so often with no apparent reason for why I haven't received them (had good to excellent reception at time of call, etc.) and only noticed that I missed a call after I received a voicemail notification. It happens so infrequently though, that I have just written them off as one-offs, so to speak.
Now, if you're not able to receive calls at all, then I suggest you take your phone in to get looked at as there may be a receiver problem with the phone. Do any messages pop-up when you receive a call? Have you tried resetting your phone to factory settings/repairing the firmware by re-installing it? Like sushi said, you have given us little to no details about what is going on, so all we can do is guess at the moment about what is going on. Give us some more info and we'll be able to give better advice. Hope this helps!
meskina
Visitor
Hello!
I have an XPERIA Mini E10i
Suddenly I have stopped hearing the incoming calls (the vibration is on place, if I turn it on).
I have tried all the obvious: the Silent mode is off, and the sound is to teh maximum.
What can be the problem?
Thanks!
Tags (2)
