New battery made problems
1976kjell
Visitor
Hi
Tried to replace the original battery today, but there is one problem:
When connecting the battery to the phone, the phone automatically tries to turn on. Then it turns off. Then the phone again tries to turn on. Then it turns off. And so on
The reason is probably empty battery, but is it normal that it turns on imidiatly aftern cobbecting the battery? Tried to charge it also, but still turns on and of
When going back to the old battery, the phone was optimises (or maybe updating is the right word?) over 300 programs and it takes about 20 minutes. Then it turned on and a code was needed. It works ok now with the old battery
Is it typical problem while installing a new battery, that it turns on and off?
Or maybe the battery is bad
0 REPLIES 0
