Mobile silent options problem.
Ihsan3
Visitor
After updating to marshmallow I am facingfacing problem regarding mobile silent options, I am missing most of my calls because of not ringing and not vibrating even from settings ringing volume is full and vibration is on, when I am restarting mobile then everything is going well ringing and vibration but after some time without any changes the same happening wich is very annoying, so please let me know if someone knows about it. Thanks
1 REPLY 1
profile.country.RO.title
_alexdon_
You either put your device into silent without noticing or there is a 3rd party app involved. Check if the same occurs in safe mode.
alexdon
