GPS didn't work
Aligi
Visitor
GPS didn't work
Hello I have a problem with GPS. If I make the test it didn't start. Someone knows this problem?? Thanks in advance Andrea
4 REPLIES 4
profile.country.RO.title
_alexdon_
@Aligi So in diagnostics it didn't work?
alexdon
Aligi
Visitor
Yes it's don't start
_alexdon_
In this case, try to perform a software repair using PC Companion. If that does not help, you need to contact your Local support.
alexdon
profile.country.PH.title
MarlonUk1
are you outside in the clear view of the sky when using gps? how about opening google maps?
