Android M upgrade - default keyboard + data connection problems
profile.country.BE.title
Fireblader
Member
I have upgraded my Z2 to Android M last week.
Since then, the keyboard is reset to US qwerty after each reboot.
I have two keyboard languages enabled: dutch and english. (dutch is my default language)
In the past (Lollipop), the keyboard always stayed on the last selected language.
With Android M this in no longer the case.
Very anoying...
Also ever since the Android M upgrade I have lost my data connection 3 times already. Cellular signal still OK, but no
data connection.
It's not a provider problem, as other phones on the same provider do not loose there data connection.
After a reboot of the Z2, the data connection is back (4G signal).
Any ideas???
2 REPLIES 2
profile.country.PH.title
MarlonUk1
try to boot in to safe mode, to see if the problems still are present.. if yes, then it must be a recent 3rd party app that is causing the problems.
if not try to perform software repair using Xperia Companion
Fireblader
Member
Probleem only occurs with the Google Keyboard, not the Xperia keyboard.
Switch to the Swiftkey keyboard for now, which is way better than the Xperia version.
