32.2.A.0.224-R4C home button issue
profile.country.NL.title
OmarSaidi
Member
Android 6.0.1 with build number 32.2.A.0.224-R4C
No improvement in this update!
1- First problem battery consumption is high
2- If you press the home button then you come back to the home screen and if you want to return to the app it remains in the place you had already been there! See below for an example
Android
3- Dail path still vibrates after disabling it in the vibration menu.
4- Stuttering audio during calls when Skype is in the background
After an android downgrade to the old ROM now I use Android 32.0.a.4.11 and it works perfectly.
2 REPLIES 2
Bugmenotsony
Visitor
Please test in the safe mode, if this is happening. Does this happen with all apps or just with those which use landscape.
Bugmenotsony
Visitor
2.) This is not changeable by now, if it was on side 2, it will return to side 2.
Sony should make an update for "Home-Version"
