XA Ultra ISO changes to auto, bad macro focus in auto mode
victor91r
HI. There is some bugs in XA ULTRA:
1)iso and SCN changes nothing. I take photos with manual iso 100(or 200 or xxx), but iso changes to auto,take photo in auto, and in EXIF iso is 100.
2) bad macro focus in auto:
-Focusing
-I take photo
-Focusing again (?!!?!?)
-Bad photo
3)sometime photo saves very long time.
4)teleservice.apk always says about mobile data connection/disconnection. If no signal, if signal is found,if restart,if change 3g to 4g, plesae, stop it!(
P.s. I do restoring in pc companion 2 times
Tag (2)
victor91r
Bug with focus fixed in new firmware
7 RISPOSTE 7
profile.country.PH.title
MarlonUk1
since you alread did a software repair using Xperia Companion, i suggest to have your device checked for hardware fault at your local service center Local support
Xperia Tutorial Photography
victor91r
No,this is 100 %program bug in all xperias XA ULTRA. In camera fv-5 or other cameras all okay.
1adrian1
Yeah cause you know better I suppose..
victor91r
Riand
Still bad focus in new firmware.
36.0.B.1.111.
teacupperr
i have the XA and it will not macro.  i fb msgd sony and they said that the XA doesnt have a macro function. but it should macro on auto focus, my moto did and my boyfriend's Z5 can do it. i use macro more than anything
teacupperr
sony have sent me a msg saying that i have to do check my software and after that take if a repair.
they say there is no recognised fault with the marco and that it must be my handset
