My phone is Sony Xperia X F5121 Dual Sim and it's colour is Gold Lime I bought it in 2017
Lately I noticed my phone drains so fast even when I'm asleep
Idk what's wrong but it isn't being the same anymore
Batteries don't live forever, however fast drain is not usual.
In most cases a cleanup will help.
Do a Software Repair with Xperia Companion
Do NOT restore all apps, keep your machine clean.
Just the most urgently needed.
If you don't want to go that way you can try to find the apps that drain.
In Settings do a search for 'consuming'.
You will find the Consuming Apps that is located in the Battery section.
Hi @EdinDzekooo, sorry to hear about this.
There doesn't seem anything really standing out in the screenshot that you provided, however could you try and restart your device in safe mode and see if you experience the same battery when downloaded applications aren't loaded.
Let us know how it goes!
