TDG BR 250 3D glasses
SOLVED
profile.country.en_GB.title
assimb
Explorer
hi
I recently upgraded to the new 3d glasses from sony (my old ones were br100) and i must say they are a big improvement. the previous model br100 you could not watch 3D for long as your eyes started to hurt.
they are also much lighter and more comfortable, i am still finding the best settings for them but all in all much happier 3D experience.
whhat have others people found with thier experience with these glasses?
1 ACCEPTED SOLUTION
Accepted Solutions
Catmambo
Contributor
They are backwardly compatible, so you are fine to use new glasses on 2010 TV's :slight_smile:
Thanks
4 REPLIES 4
Catmambo
Contributor
Yep I prefer them too, just much easier to wear all round..
WJH602
Visitor
I am also considering upgrading to the BR250 glasses but I am concerned they will not work with my KDL-46 HX803 TV. What model do you have?
Catmambo
Contributor
Thanks
iagibso49
Member
Do the new glasses reduce flicker in a way that the old ones didn't?
