Z4 Tablet flashing red light, FAT corruption on internal SD card
brickedz4
Visitor
My tablet was left charging overnight while connected to my PC, with Android Studio running (coincidentally). When I checked it in the morning, it had the blinking red light problem and would not respond to power / volume controls to either start or soft reset.
Then I noticed that the Console Log in Android Studio showed pages of errors that occurred overnight. They seem to indicate the file allocation table is corrupt. There are many messages similar to this:
05-09 06:46:25.803 2949-2949/? W/fsck_msdos: Dump_fatentry;NULL  pointer
05-09 06:46:25.803 2949-2949/? I/fsck_msdos: Clear chain starting at %u ?
05-09 06:46:25.803 2949-2949/? D/fsck_msdos: fat:0x7fa5c60700 ,head :62477 ,trunc :62558
05-09 06:46:25.803 2949-2949/? D/fsck_msdos: clearchain:fat:0x7fa5c60700 , head(62477) ,length(82)
05-09 06:46:25.803 2949-2949/? E/fsck_msdos: Cluster chian is wrong
05-09 06:46:25.803 2949-2949/? I/fsck_msdos: head: 0x63024:
05-09 06:46:25.803 2949-2949/? I/fsck_msdos:  0x63024:0x111 ->
05-09 06:46:25.803 2949-2949/? I/fsck_msdos: EOF
I would like the reflash the firmware but, unfortunately, it is no longer is detected as a USB device by the flashtool.
Any suggestions on how to proceed? Is it possible to reflash by booting from the removable SD card?
0 REPLIES 0
