SO-05F - my mistake, can I fix it?
Ubiknoir
Visitor
Hi,
Bought a lovely Xperia Z2 Tablet while traveling... Perhaps this is the first mistake.
Bought a SO-05F in Japan, managed to have the device unlocked from the NTT-Docomo network, so that I can use data connection back home, but alas... there's a problem.
The SO-05F has a locked bootloader, and a bunch of useless NTT-Docomo bloatware that I would just love to get rid of.
So the question is really simple.... Is there any way to unlock the bootloader and live happily ever after?
The tablet is beautiful, and performance is flawless, unfortunately with my mistake of getting not t purely Sony device, but a NTT-Docomo branded one since I will never use the tablet on the NTT network I will not have any further upgrades...
If anyone knows  how, please help!
Cheers
6 REPLIES 6
Uliwooly
Just flash a different firmware and that should do it, don't unlock the bootloader
Ubiknoir
Visitor
Thanks for the reply!
Any idea which FW would be the closest match for SO-05F? It's basically the LTE+WiFi version with 32Gb of storage...
Thanks again!
Uliwooly
You should check the xda forum to be certain
byrd
Visitor
I have the same Tablet.  Did you ever find a solution?
Thansk
atpdnc11
Visitor
hello
I BAUGHT SO-05F FROM JAPAN IN APRIL 2016
By sending rquest to to unlocker web i unlocked it paying 1800 rs
by using kingo root rooted it
i uset no botware app to remove japanese apps except tv
by using pc companion i upgraded i to lolipop
working fine
