Lost customise icon top right
SOLVED
profile.country.en_GB.title
judypolarbear
New
Help - I seem to have lost the + that should be on the top right of my screen - similarly a long hold on the screen doesn't work either.I guess I may have tweaked something in error can anyone help me to sort it out
Thanks in advance
1 ACCEPTED SOLUTION
Accepted Solutions
rich912
Contributor
Hi judypolarbear,
This disappeared with the ICS upgrade. The procedure is now..
To change the wallpaper tap and hold on the screen.
To add a widget open Apps and then hold on the application you would like to add to a home screen.
To add a widget, open Apps and then click widgets on the top left cornerr.Tap and hold on the widget to add it to a home screen
Rich
Go n-éirí an bóthar leat
1 REPLY 1
rich912
Contributor
Hi judypolarbear,
Rich
