How to repair exFAT files on SDXC flash card?
profile.country.uk_UA.title
rzawada
Visitor
I inserted 64GB SDXC flash card, used for recording video on Samsung QF-20 camcorder into Sony tablet. Discovered later tht the tablet is not compatiple with the exFAT file system that is used by the SDXC card, so the files were corrupted, and they will not play now, even in the Samsung camera.  I am prompted to reformat the memory in the camera, if I want to use it again (obviously, I did not, not to lose the files).  Is the any way to recover/repir the files from the SCXC memory and copy them to a different media, or hard drive?
Thanks for Your Help!
Roman
2 REPLIES 2
rich912
Contributor
Hi Roman,
I suggest you try a file recovery utility such as Aidfile – free trial. I have no idea whether you need the full version to actually recover the files, but this should give some indication of whether the files are recoverable.
http://www.aidfile.com/download.htm
There are probably many such utilities out there if you Google...
Rich
Go n-éirí an bóthar leat
profile.country.en_GB.title
sharonflowers
New
exactly the same happened to me...twice! have lost lots if things...have you found a solution to this ?
thanks
