Connection failed
profile.country.en_GB.title
kaibil
Visitor
Connection failed
I am unable to connect to the internet using wifi.  The Vaio sees the server, pings it but can't get a response. All other machines using the same router have no problem.  Is it possible to connect an ethernet cable?  Urgent as I cant update anything.
Kaibil
Message was edited by: kaibil
1 REPLY 1
gfds23467
Visitor
have you tryed pressing the reset button on the tablet and if this dosent work try the reset button on the router
hope this helps
