After upgrade Zony Experia Tablet Z (LTE) till Android 4.4.4 tablet PC cannot find sd-card
Solved! Go to Solution.
There is restricted access on 4.4.2 too,but only that 3rd party apps cannot write on SD.
How resolved this problem? Android cannod indentify sd card phisically
You can try to remove the microSD,turn off the device and put the card back.Turn on the device.
Sorry, but you recomendation don`t resolve problem.
Thanks, problem resolved!
Great.
couldn´t sony add some bypass for 3rd part apps?
Really do not know.
Hey! How did you solve this problem? My tablet soesn't see the SD card at all.
