32.3.A.0.372 android 7 upgrade and BKB50 language switch issue
gbil
After upgrading to 32.3.A.0.372 it is no longer possible to
1. select more than one languages for the BKB50 keyboard
2. and of course switch to another language
This is a major step backwards compare to previous android version therefore I expect that it will be fixed really really soon.
34 RISPOSTE 34
Rapid-eraser
Is there any update to this problem ?
Namelessonne
The issue still not fixed after so much time and so many updates. It's unbelievable.
Namelessonne
I found a solution: https://play.google.com/store/apps/details?id=com.apedroid.hwkeyboardhelper. This paid keyboard allows to create up to 3 layouts for the physical keyboard. Source: https://android.stackexchange.com/questions/188513/android-7-tv-wireless-keyboard-language-switch-no.... Checked. It works!!!
Namelessonne
How does it look:
When the app running in the background detects an external keyboard, a pop-up window appears, in which you can swith from SwiftKey to the External Keyboard Helper Pro keyboard. It deactivates any on-screen keyboard displaying. Then you press your assigned keyboard combination to switch between languages the way it was meant to be.
StepanSolovyev
Still not been fixed.
