After 5 months of usage I suddenly found that that the TV wouldn’t turn on after it was off for several hours ( typically overnight). I found that if i turned off the power at the wall or unplugged completely and then switched back on it would start. I checked the power point and had no issues with anything else plugged in at the wall. I tried resetting the TV but still had the same issue. A friend suggested I disconnect the Ethernet cable to the TV and only use WiFi (he installs audio equipment for a living). Ive tried this and it worked, I haven’t had the issue since (so far 2 weeks).
Anyone have any ideas what this issue is and should I be worried about it coming back? Makes no sense to me that it has something to do with the Ethernet cable so wanted to reach out to the community to see if anyone knows about this. Thanks
