XNV-77-BT FM TUNER
profile.country.en_GB.title
sean2e0saf
Visitor
XNV-77-BT FM TUNER
Hi all i have just bought the xnv-77bt i have noticed that the radio station info is not displayed on the display my old pioneer avic used to do this is this not supported on this model...?
1 REPLY 1
Drumzman
New
Hi sean2e0saf,
This unit has RDS functions, so as long as you are listening to a station that broadcasts RDS information then you should get the station name displayed.  You need to at least have the 'AF' function activated for this to happen though.
If you have AF switched on and you're listening to a station that you know has station info, then it might be worth checking your aerial - you do need a decent signal to receive this extra information even if you just have enough signal strength to hear the broadcast.
Hope this helps
