WI-C300 faulty L/R balance
Hi there, I have had my Sony WI-C300   headphones for a couple of months now and and when I switch them on today the balance between the left and right earbud is way off?
I have checked on a few different sources and it's the same on all? Right earbud is fine but the left one is working but sounds as though it's turned down to around 25 percent?
Can anyone please help as the Sony troubleshooter says I should take them back to my retailer (TK-Maxx) and they will sort it out???? I have also factory reset them and it's still the same 😠
I want Sony to check them as it's obviously a faulty earbud, they've hardly been used and now this?
Many thanks for your time
Martin
1 REPLY 1
EdwinaU
Moderator
Hi there,
Welcome to the community.
We would recommend you follow the troubleshooter advice. You could also try the Sony repair and warranty page here to see if it offers any other options.
Best wishes,
Ed
