WH-XB900N Headphones connection to Samsung smart TV [Solved]
PaulHypno
New
I have a Samsung TV UE43NU7400 and I have previously connected a very cheap set of bluetooth headphones instantly to it. No problem ever with pairing.
But I've just bought Sony WH-XB900N headphones but the TV just can't find them to pair. I've got the TV to 'forget' existing pairings but that makes no difference. But the cheap set will once again pair, perfectly.
I have hearing difficulty so bluetooth headphones are important to me, that's why I bought what I'd hoped was a good headphone set. Can anyone offer any advice? Thanks
1 REPLY 1
PaulHypno
New
OK, solved. I needed to hold down the bluetooth button on the headphones for 5+ seconds and then the TV discovered it.
