SONY XAV-601BT
profile.country.en_GB.title
HONEBOY
Visitor
SONY XAV-601BT
Why dont my stalk controls work with my sony xav-601bt? i have bought the correct lead and patch lead etc?
1 REPLY 1
Drumzman
New
Hi HONEBOY,
You don't say whose adapter & patch lead you're using, but I would say a call to the manufacturer might be the best option, especially if you've followed their guidance as to which is the correct combination to use.
Personally I've used the adapters and leads from a company called Connects2 that I've always found to be good (http://www.connects2.co.uk/), so this might be another option if it's not their products that you're using now.
Hope this helps.
