Hi, i've got problem with my new walkman nwz-s765, when I'm trying to connect it via bluetooth to my SRC schuberth headset for motorbike helmets, established connection is for max couple of seconds than it disconnects again. In my opinion problem lies in software, either it is mp3 or headset i dont know, I have compared A2DP versions seems to be the same, 1.2v. also, I can connect my walkman to laptop via bluetooth and theres no problem's whit connection whatsoever, same with headset it connects to any other devices like iphone for example without any problems.
Both devices were paired and reset hundred times still same thing.
If anyone have some ideas what to do i'll really appreciate any help.
