no usb support
delbob_1
Explorer
no usb support
I just bought and fitted a cdx-gt450u and when i connect my Ipod (4th generation) to the usb port and select usb on the unit it says no usb support, am i doing something wrong? Is there something else i need to do to use the ipod with this unit?
Thanks for any information
Delbob_1
1 REPLY 1
profile.country.en_GB.title
Drumzman
New
Hi delbob_1,
Not sure on this one, but I suspect that iPods don't conform to the same standards as a generic USB stick type mp3 player (which I'm guessing is why some Sony stereos have a specific iPod connection as well as a normal USB connection), and this is why nothing is happening.  Certainly the compatibility guide on Sony's website for the GT450 makes no mention of any iPod models.
My suggestion would be to use the good old fashioned 3.5mm jack input on the GT450 via the headphone output of your iPod.
hope this helps.
